YouDontKnowJack Posted June 11, 2006 Share Posted June 11, 2006 this is on a 1998 toyo/lexus es/camry I can open the front right door from the inside, but not from the outside. When I pull on the door handle from the outside, it's not latching onto anything, so it won't open. anyone know what part might be malfunctioning? i'm looking at the repair manual, and there are tons of parts in the front door. looks complicated. Quote Link to comment Share on other sites More sharing options...
platinum00 Posted June 11, 2006 Share Posted June 11, 2006 i had this problem with my 96 all it was is a little plastic clip that holds the, what do you call it the rod, that pulls the latch. Quote Link to comment Share on other sites More sharing options...
walterh Posted April 23, 2007 Share Posted April 23, 2007 i had this problem with my 96 all it was is a little plastic clip that holds the, what do you call it the rod, that pulls the latch. Right, so any pointers on opening up the door and gettting inside to make the repairs? Quote Link to comment Share on other sites More sharing options...
Bagolex Posted June 3, 2007 Share Posted June 3, 2007 did you fix this? How did you get to the lock mechanism. I'm having the exact problem with the front driver side. Quote Link to comment Share on other sites More sharing options...
Shayan Posted June 4, 2007 Share Posted June 4, 2007 me2 i took the panel off, all i see is a speaker, some wires, but its all metal how do you get to the lock stuff? Quote Link to comment Share on other sites More sharing options...
