Car was fine they started having hesitation at any speed while you hold the gas pedal down but if you increase speed it goes away cruise control is also fine, the lights came on: CHECK ENGINE, VSC, TRAC OFF, and i pulled the code 0020 which I can't find anywhere, when I clear the code it goes away the lights go out, but it comes back on, any suggestions?
I can't find 0020 code ANYWHERE, any help would be appriciated, THANKS!
Code 0020 is not referenced, are you sure of the code?
that is exactly what I was thinking. Are you sure it wasn't code P0200?
steviej
steviej
Thanks for the help guys, I know exactly what you are thinking the same as I was, so I turned the car off and reconnected my reader 3 times just to make sure and the code was 0020, that's why I asked cause it didn't show up anywhere, anyway after a few hunderd miles of driving the car, and it drove rough! it finnaly cleared itself and now the car is fine!
I was going to try a different brand reader but never got around to it..
Thanks anyway!
