SoufSidah09 Posted June 9, 2006 Posted June 9, 2006 Car was fine they started having hesitation at any speed while you hold the gas pedal down but if you increase speed it goes away cruise control is also fine, the lights came on: CHECK ENGINE, VSC, TRAC OFF, and i pulled the code 0020 which I can't find anywhere, when I clear the code it goes away the lights go out, but it comes back on, any suggestions? I can't find 0020 code ANYWHERE, any help would be appriciated, THANKS!
Al Cannaday Posted June 11, 2006 Posted June 11, 2006 I can't find 0020 code ANYWHERE, any help would be appriciated, THANKS! This website has a directory of OBD II diagnostic codes. Code 0020 is not referenced, are you sure of the code? http://autorepair.about.com/cs/troubleshoo...bl_obd_main.htm
steviej Posted June 12, 2006 Posted June 12, 2006 Code 0020 is not referenced, are you sure of the code? that is exactly what I was thinking. Are you sure it wasn't code P0200? steviej
SoufSidah09 Posted June 19, 2006 Author Posted June 19, 2006 Code 0020 is not referenced, are you sure of the code? that is exactly what I was thinking. Are you sure it wasn't code P0200? steviej Thanks for the help guys, I know exactly what you are thinking the same as I was, so I turned the car off and reconnected my reader 3 times just to make sure and the code was 0020, that's why I asked cause it didn't show up anywhere, anyway after a few hunderd miles of driving the car, and it drove rough! it finnaly cleared itself and now the car is fine! I was going to try a different brand reader but never got around to it.. Thanks anyway!
Toysrme Posted June 20, 2006 Posted June 20, 2006 AFAIK that isn't a code. OBD-II codes start at P0100.
