Air Force Rascal Posted June 8, 2006 Share Posted June 8, 2006 Does anyone know where the Flasher Unit on a 93 SC400 is located..I've looked in the driver's side kick panel fuse block and up under the dash..and still can't find the little (*%&$&(*..? Thanks for any help.. :( Quote Link to comment Share on other sites More sharing options...
2JZ_SC Posted June 9, 2006 Share Posted June 9, 2006 It's in the junction block on the Left kick panel. The block is in a "p" shape, the horn relay is at the top right then the next row below it is the turn signal flasher and the seat heater relay (if equped). hope this helps. Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted June 9, 2006 Author Share Posted June 9, 2006 It's in the junction block on the Left kick panel. The block is in a "p" shape, the horn relay is at the top right then the next row below it is the turn signal flasher and the seat heater relay (if equped). hope this helps. Thanks for the help..is it one of the ones that are black in color and about an inch in diameter..? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 9, 2006 Share Posted June 9, 2006 Easiest way to find one is to turn the turn signal on and feel/listen the clicking on the relay. Quote Link to comment Share on other sites More sharing options...
2JZ_SC Posted June 9, 2006 Share Posted June 9, 2006 That's it. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 11, 2006 Share Posted June 11, 2006 is it clicking faster with all the lights working or sumthin? Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted June 11, 2006 Author Share Posted June 11, 2006 is it clicking faster with all the lights working or sumthin? Thanks everyone..for your input..I got the problem fixed...air force rascal Quote Link to comment Share on other sites More sharing options...
