SlammedLs400 Posted June 4, 2006 Share Posted June 4, 2006 i can only push the little button thingy that goes up when you turn the crank so much but its still not enough to bolt it on. is there any trick or something yall did to put it back on? Quote Link to comment Share on other sites More sharing options...
Threadcutter Posted June 4, 2006 Share Posted June 4, 2006 i can only push the little button thingy that goes up when you turn the crank so much but its still not enough to bolt it on. is there any trick or something yall did to put it back on? Slammed: Put it in a vice, gently compress it, insert an expendable drill bit into the hole, all the way through. Use a bit that is the biggest that you can fit through the hole, as it will have the most strength. Mount the tensioner completely, pull on the belt a little to put force against the tensioner & pull the drill rod out, using vice grips if necessary. Done...... Quote Link to comment Share on other sites More sharing options...
SlammedLs400 Posted June 4, 2006 Author Share Posted June 4, 2006 i can only push the little button thingy that goes up when you turn the crank so much but its still not enough to bolt it on. is there any trick or something yall did to put it back on? Slammed: Put it in a vice, gently compress it, insert an expendable drill bit into the hole, all the way through. Use a bit that is the biggest that you can fit through the hole, as it will have the most strength. Mount the tensioner completely, pull on the belt a little to put force against the tensioner & pull the drill rod out, using vice grips if necessary. Done...... Im sorry i dont have a clue what you just said can you explain it alittle more please. Quote Link to comment Share on other sites More sharing options...
SlammedLs400 Posted June 11, 2006 Author Share Posted June 11, 2006 i can only push the little button thingy that goes up when you turn the crank so much but its still not enough to bolt it on. is there any trick or something yall did to put it back on? Slammed: Put it in a vice, gently compress it, insert an expendable drill bit into the hole, all the way through. Use a bit that is the biggest that you can fit through the hole, as it will have the most strength. Mount the tensioner completely, pull on the belt a little to put force against the tensioner & pull the drill rod out, using vice grips if necessary. Done...... Im sorry i dont have a clue what you just said can you explain it alittle more please. anybody got an idea how to do it?? Quote Link to comment Share on other sites More sharing options...
