lx_and_ls Posted May 15, 2006 Share Posted May 15, 2006 I just replaced the rear upper control arm of my '95 LS with 217,000 km because of excessive play in the ball joint. While doing this I noticed that the rear axle carrier arm bushings are totally gone. I'm planning to replace them as per: http://www.lexls.com/tutorials/suspension/rcabushings.html I called my dealer in Toronto area, but they don't seem to carry these aftermarket kits. Does anyone know where I can buy these locally? Thanks! Quote Link to comment Share on other sites More sharing options...
AussiLS400 Posted May 16, 2006 Share Posted May 16, 2006 www.foreignautosalvage.com. Not in Canada but you can order ADUS bushes in days from these people. Quote Link to comment Share on other sites More sharing options...
lx_and_ls Posted May 16, 2006 Author Share Posted May 16, 2006 www.foreignautosalvage.com. Not in Canada but you can order ADUS bushes in days from these people. Thanks. I ordered my parts here. Very friendly people, and fast response to my email. I did a search on ADUS but was unable to find the manufacturer's website. Are these Japanese import? Quote Link to comment Share on other sites More sharing options...
AussiLS400 Posted May 17, 2006 Share Posted May 17, 2006 After replacing the carrier bushings i found movement in my outer bush of the lower control arm which i also replaced with adus bush's. I had to get a wheel alignment done and was told the new bush's put the rear wheel alignment out about 15%. The car now drives much tighter. Don't know where adus are made, i gather they wholesale to business only. Quote Link to comment Share on other sites More sharing options...
lx_and_ls Posted May 26, 2006 Author Share Posted May 26, 2006 After replacing the carrier bushings i found movement in my outer bush of the lower control arm which i also replaced with adus bush's. I had to get a wheel alignment done and was told the new bush's put the rear wheel alignment out about 15%. The car now drives much tighter. Don't know where adus are made, i gather they wholesale to business only. I just put the carrier bushings in. If it hadn't been for the cup-shaped ball joint extractor, I would have never gotten those bushings out. They were rusted pretty badly (Canadian winters, eh). The rubber was almost completely gone. I'll have a look at the outer bushings as well. I havn't driven the car yet to see if there is an improvement. I have two comments/questions: - The 136 ft.lb of torque seems excessive for the little tubes in the Adus bushings. I think I was just crushing them, so I torque'd to about 100 ft.lb. The tubes are thinner than the original Lexus tubes. - It looks like the the Adus bushings are made in a garage. I could have easily made these for $0.50 if I had know the dimensions. The polyurethane wasn't even degassed. I wrote down the dimensions for the rear bushings. Does anyone have the other dimensions? Quote Link to comment Share on other sites More sharing options...
