my dads 97 odyssey has 138k miles on it. its got stock rims(actually caps cuz its only an lx version) but since of the high mileage, do the rims deteriorate in a way that they blow out the tires? we had an issue before that in this set of 4 tires, only one particular tire(same rim) blew out 2 tires. both didnt hav nails or punctures in them. today a different tire( dif rim) blew out but same location (right front). suggestions? I highly doubt it's a coincidence <_<
So it has steel wheels and hubcaps?
Steel wheels can become bent and they can warp. The good news is they can be fixed. I doubt the wheels have anything to do with your blowouts. Were they blowouts at speed or did they just go flat?
they actually all went flat. none of them popped. i wud have thought it was a bad steel due 2 age and use but what a coincidence that they all happened on the front right?? <_<
Its probably that the steel along the rim became warped or bent. I'd replace all the steel wheels.
thats what i figured too. thanx for backing me up on that decision. my dads thinkin of getting the alloy wheels that came with the EX version. only thing i hope we can still find good ones. i highly doubt that honda still has new rims for a 97 odyssey. <_<
Go to www.aaarims.com
thanx but they don't have any stock alloy wheels for a 97. i'll just have to look at the honda forums. thanx ;)
They should...
Here you go:
http://www.lakeshorewheelandtire.com/cgi-b...ile=wheel.setup
They basically have EVERY OEM wheel.
hmm strange, if u didn't give me that link, i didn't know where to find it. lol :whistles: wow. i can't believe rims for this car is sooo expensive. i'd thought they'd run around $50-$70 :(
