the seat moves up/down but not forward backwards, the spiral gear underneath is not moving on the left side, the right side works fine, all other components on the driver seat are fine? thanks in advance for your guidance>>)
only thing i can say is remove the seat and check to see if it is still being powered it might be a simple plug for it you can't see
