twinelmskao Posted April 13, 2006 Share Posted April 13, 2006 04 RX330 AWD with 66K miles 60K service done change oil/fluid regularly maintenance required light on today why is that? cant figure that out opinion/advice highly appreciated Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted April 13, 2006 Share Posted April 13, 2006 well...you are 6 thousand after your last service...which is suppose to be every 5 thousand miles...so...you could either go get your service, or you can reset the timer some how, somep eople know how to do that Quote Link to comment Share on other sites More sharing options...
twinelmskao Posted April 13, 2006 Author Share Posted April 13, 2006 thanks rx330driver just got the tips from toyota owners club forum and it worked 1)turn ignition key to ON and press the odometer button until the display reads actual mileage 2)turn ignition key to OFF 3)hold in the same button you used in step 1, while holding the button in,turn ignition key to ON the "maint reqd" light should blink and go out Quote Link to comment Share on other sites More sharing options...
