Joodafoo Posted April 11, 2006 Posted April 11, 2006 So i just got the new PS pump and alternator put in my 93 sc400, and everything is hooked up. We were going to flush the PS but then we realized that there was no power going through the car. The lights didnt work, the auto adjusting wheel didnt budge, and the car wouldnt crank at all. So we put it in neutral and pulled it out and tried jumpstarting it. Nothing, no cranking at all. Well it could have been many things wrong with it but we checked the fuse box. The ABS fuse is broken, and the metal in the alternator fuse wasnt connecting. Im not sure if it was supposed to be like that, or if it was just an incredibly clean break, but i popped off the clear clip and used pliers to try to connect them, i guess theyre supposed to be like that since they wouldnt stay in place. Well unsure what it is, i put the transmission override cap back on the button, and i noticed that this time the door light came on along with the door open signal on the dash. Well, its got some juice it seems, but for some reason it still wouldnt crank or turn on the headlamps. Im not sure if theres some stupid electrical lock on the car or somethign got disconnected or what. Im thinking of replacing those 2 fuses first, and then try and figure out whats wrong with it. If anyone has gone through the same thing or can help me out with this, it would be much appreciated.
SKperformance Posted April 11, 2006 Posted April 11, 2006 I would start by checking the main fuses and other relays you may have popped a few of them with the battery terminals touching or grounding out.
Joodafoo Posted April 13, 2006 Author Posted April 13, 2006 How would i take out the bolted fuses? I tied taking a phillips head to em but they wont budge.
