M500 Posted March 16, 2006 Posted March 16, 2006 I have a set of 19" x 8" wheel in 5 x 114.3 with 35mm offset. Would they fit on my 06 LS430? Anyone done it?
SKperformance Posted March 18, 2006 Posted March 18, 2006 Most wheels will not fit any 95 and new LS because of the large 4 piston calipers. The stud pattern is correct. the offset can be used for that width of rim but you also need the center bore size . The only way to tell if the rim fits is to test fit its clearance from the calipers to the spokes.
