Mark B Posted March 15, 2006 Posted March 15, 2006 Hi all, Does the factory remote key for the 1990 LS400 immobilize the car ?? (EG. Cut fuel pump, or ignition or ecu) Or does it just lock and unlock the doors ??? Thanks....
larryp Posted March 15, 2006 Posted March 15, 2006 Don't know but it would be easy to find out. Leave window down and lock car with remote. Reach in and open door (be prepared for alarm) and then try to start car.
Mark B Posted March 16, 2006 Author Posted March 16, 2006 Don't know but it would be easy to find out. Leave window down and lock car with remote. Reach in and open door (be prepared for alarm) and then try to start car. I just managed to check it... it does NOT immobilize the car B-( DAMN... I will have to install my own kill switch.... Regs Mark.
SKperformance Posted March 17, 2006 Posted March 17, 2006 no imobilizer key just a factory alarm which should have a starter cut off if it is triggered when armed.
Jacob Posted March 17, 2006 Posted March 17, 2006 no imobilizer key just a factory alarm which should have a starter cut off if it is triggered when armed. What’s the difference between the immobilizer and starter cut off?
SKperformance Posted March 18, 2006 Posted March 18, 2006 An immoblizer key needs the transponder in the head to activate the ecu otherwise it just turns over. As even if you break the igntion the car will not start even if you have a key copied. A starter cut off can be bypassed easier as you can open the door to disarm the alarm then break the igntion to drive it away. Or a copied key can be used to drive it away easier
