soorg Posted March 11, 2006 Share Posted March 11, 2006 Two questions: Does anyone know if you leave an iPod plugged into the auxiliary input does it drain the car battery when the car is turned off? Can an internal E-Z Pass be used in the new IS? Does the windshield UV protective coating prevent normal operation of the E-Z Pass, or do I need to use an externally placed E-Z Pass instead? Quote Link to comment Share on other sites More sharing options...
_tjp_ Posted March 11, 2006 Share Posted March 11, 2006 I don't see any way a device plugged into the Aux port could drain the battery withthe car off. The audio system is shut down. I have used the "Fast-Trak" transponder here in the SF Bay area without any problems. I have the transponder sitting on the dashboard. I don't have it fixed to the windshield as I hate the look of it. Two questions: Does anyone know if you leave an iPod plugged into the auxiliary input does it drain the car battery when the car is turned off? Can an internal E-Z Pass be used in the new IS? Does the windshield UV protective coating prevent normal operation of the E-Z Pass, or do I need to use an externally placed E-Z Pass instead? Quote Link to comment Share on other sites More sharing options...
jimburnz Posted March 14, 2006 Share Posted March 14, 2006 no it wont drain but i get lot's of engine noise.. Radio shack has a part to fix. Quote Link to comment Share on other sites More sharing options...
