jjewell Posted March 5, 2006 Posted March 5, 2006 oh yea, replaced the sway bar end links & bushings. Got the end links (both) off ebay cheaper than one priced high @ stealership. Had to get the bushings @ stealership though. 45 minutes, drive test & no more noise!
Miguel Posted March 5, 2006 Posted March 5, 2006 oh yea, replaced the sway bar end links & bushings. Got the end links (both) off ebay cheaper than one priced high @ stealership. Had to get the bushings @ stealership though. 45 minutes, drive test & no more noise! Great :D
sovietlexus Posted March 6, 2006 Posted March 6, 2006 what kind of bushings are these exacly....i have the same problem
jjewell Posted March 6, 2006 Author Posted March 6, 2006 what kind of bushings are these exacly....i have the same problem The rear stabilizer (sway) bar bushings. There are 2 of them. If yer gonna do it, do the 2 end links too. B)
jjewell Posted March 6, 2006 Author Posted March 6, 2006 would camry ones work? The local toyota stealership said I had to get em @ Lexus. $23 for 2 rubber bushings! Ah well, at least it's fixed!
SnesleyWipes Posted March 6, 2006 Posted March 6, 2006 what kind of bushings are these exacly....i have the same problem The rear stabilizer (sway) bar bushings. There are 2 of them. If yer gonna do it, do the 2 end links too. B) What is an "endlink"?
jjewell Posted March 6, 2006 Author Posted March 6, 2006 what kind of bushings are these exacly....i have the same problem The rear stabilizer (sway) bar bushings. There are 2 of them. If yer gonna do it, do the 2 end links too. B) What is an "endlink"? They are a dogbone shaped piece about 4" long with ball joints on either end. One end to the end of the sway bar & the other end to the strut. I did the test mentioned in the FSM for testing torque on the end link joints and all of them were loose & worn out. Tight, smooth & quiet now!
