ko90ls Posted March 2, 2006 Share Posted March 2, 2006 just changed the oil about two days ago and filled the tires. checked oil level while car was cold, right where it needed to be. so then i drove around and warmed the car but couldn't get a 100% accurate reading? should i stick with the cold level or drain some oil? Quote Link to comment Share on other sites More sharing options...
RFeldes Posted March 2, 2006 Share Posted March 2, 2006 just changed the oil about two days ago and filled the tires. checked oil level while car was cold, right where it needed to be. so then i drove around and warmed the car but couldn't get a 100% accurate reading? should i stick with the cold level or drain some oil? I was always told to check the oil in the AM while the engine was cold. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted March 2, 2006 Share Posted March 2, 2006 capacity is 5.5 quarts so if you put back 5.5 qt youre ok Quote Link to comment Share on other sites More sharing options...
