krymsn Posted February 27, 2006 Share Posted February 27, 2006 What's up fellas. I have a minor problem with the pressure of the wiper fluid on the drivers side of my 2000 gs 300. When I try to clean the windshield, the wiper fluid shoots out just fine on the passenger side but doesn't even make it to the windshield on the drivers side. Is there some way to clean it or fix the problem? Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 27, 2006 Share Posted February 27, 2006 What's up fellas. I have a minor problem with the pressure of the wiper fluid on the drivers side of my 2000 gs 300. When I try to clean the windshield, the wiper fluid shoots out just fine on the passenger side but doesn't even make it to the windshield on the drivers side. Is there some way to clean it or fix the problem? Check to see if the orifices (3 of them ) are clogged first, Then make sure the line from the pump is clear. Quote Link to comment Share on other sites More sharing options...
krymsn Posted March 4, 2006 Author Share Posted March 4, 2006 What's up fellas. I have a minor problem with the pressure of the wiper fluid on the drivers side of my 2000 gs 300. When I try to clean the windshield, the wiper fluid shoots out just fine on the passenger side but doesn't even make it to the windshield on the drivers side. Is there some way to clean it or fix the problem? Check to see if the orifices (3 of them ) are clogged first, Then make sure the line from the pump is clear. Where would I find the orifices and the pump? Thanks! Quote Link to comment Share on other sites More sharing options...
dcfish Posted March 5, 2006 Share Posted March 5, 2006 What's up fellas. I have a minor problem with the pressure of the wiper fluid on the drivers side of my 2000 gs 300. When I try to clean the windshield, the wiper fluid shoots out just fine on the passenger side but doesn't even make it to the windshield on the drivers side. Is there some way to clean it or fix the problem? Check to see if the orifices (3 of them ) are clogged first, Then make sure the line from the pump is clear. Where would I find the orifices and the pump? Thanks! The orifices are on the hood where the fluid comes out, Sometimes they get clogged, Then open the hood and follow the lines back from where they are connected on the underside of the hood. Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted March 5, 2006 Share Posted March 5, 2006 What's up fellas. I have a minor problem with the pressure of the wiper fluid on the drivers side of my 2000 gs 300. When I try to clean the windshield, the wiper fluid shoots out just fine on the passenger side but doesn't even make it to the windshield on the drivers side. Is there some way to clean it or fix the problem? Check to see if the orifices (3 of them ) are clogged first, Then make sure the line from the pump is clear. Where would I find the orifices and the pump? Thanks! Orifice meaning the three holes where the water comes out, maybe use a needle? or toothpick? and then if you remove the fabric backing of the hood, there should be the plastic pipes where the water goes through. I have no idea where to go from there. :whistles: Quote Link to comment Share on other sites More sharing options...
