tyminski Posted February 21, 2006 Share Posted February 21, 2006 Hi, All the needle indicators on all the guages of my '92 ES300 are out. This makes it tough to read the gauge! Only once did I see them on, one morning when it was cold out (35-40 degrees) and I started the car, they flickered then went out again. They must be all controlled from one location and must be fibre optic or something. Thanks for your help! Steve Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 21, 2006 Share Posted February 21, 2006 Hi, All the needle indicators on all the guages of my '92 ES300 are out. This makes it tough to read the gauge! Only once did I see them on, one morning when it was cold out (35-40 degrees) and I started the car, they flickered then went out again. They must be all controlled from one location and must be fibre optic or something. Thanks for your help! Steve I know you are new here BUT you have got to learn how to use the search feature on these boards. This issue has been covered more than it has to. Educate yourself and get used to using these boards before you ask for information that has been covered over and over and over and over, If you can't find the info go to www.lextech.org and search there. By the way welcome to the club Quote Link to comment Share on other sites More sharing options...
