javapda Posted February 14, 2006 Share Posted February 14, 2006 If the coolant overflow reservoir is below the FULL line, do you just add straight anti-freeze to bring it up to the full mark? Quote Link to comment Share on other sites More sharing options...
Sweet95LS400 Posted February 14, 2006 Share Posted February 14, 2006 Mine was the same exact way, even when hot. I had to add about 8oz to get it to the full line. I dont know if its coincidence or not, but now the heater in the car seems to work better. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted February 14, 2006 Share Posted February 14, 2006 Red only!! from Lexus or Toyota. I see yours is red..good..keep it that way. Clean engine bay..Congrats.. Quote Link to comment Share on other sites More sharing options...
KY350 Posted February 14, 2006 Share Posted February 14, 2006 If the coolant overflow reservoir is below the FULL line, do you just add straight anti-freeze to bring it up to the full mark? You can add either coolant or water as the amount that you would be adding would be so small as not not have a great effect on the ratio of coolant to water (ratios can vary anywhere between 50:50 and 70:30 coolant - if you live in a freezing environment, then go for the 70:30 coolant ratio). If the coolant is very red you are safe to just add water. If the colour is a light red / slightly pinkish, then add coolant. Actually, your coolant looks quite red, so I'd just add water. Also, I don't like to mix different coolants when I don't know the original coolant formulation. Quote Link to comment Share on other sites More sharing options...
