tc5953 Posted February 8, 2006 Share Posted February 8, 2006 So just like it says i have condensation inside my left headlight lens and i need to know if anybody knows how to fix it and what is causing the probem? thanks for the help!!!!!! Quote Link to comment Share on other sites More sharing options...
Toysrme Posted February 8, 2006 Share Posted February 8, 2006 Get it in a dry enviornment to dry it out. Otherwise, you gotta take it apart in the oven. Not a big deal... See the angel eye post that is stickied, or any "how to do clear corners" post on how to take it apart. Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted February 11, 2006 Share Posted February 11, 2006 Get it in a dry enviornment to dry it out. Otherwise, you gotta take it apart in the oven. Not a big deal... See the angel eye post that is stickied, or any "how to do clear corners" post on how to take it apart. ah, but there is another way...if you dont have projectors...remove the bulb and dump rubbing alch. through a funnel...wont take much. it will evaporate, and take the water with it. a cup or so should do it. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted February 12, 2006 Share Posted February 12, 2006 Take out the bulb and blow dry into the unit. The water will evaporate very quickly. Let it sit out over night, then in the morning put the bulb back and you're all set. I just had this happen to my rx300's tail light. Did that and haven't had the problem since! Quote Link to comment Share on other sites More sharing options...
