akewlguy Posted January 31, 2006 Share Posted January 31, 2006 Just bought a small over head bulb (185 I think) and it is rather dull. THe original is bright white. Are these Lexus parts? Secondly does anyone use the clear back lights? If so did you replace the center white bulb with a red?? So it does not look like your going in reverse when the brake is pressed. Quote Link to comment Share on other sites More sharing options...
branshew Posted January 31, 2006 Share Posted January 31, 2006 Just bought a small over head bulb (185 I think) and it is rather dull. THe original is bright white. Are these Lexus parts? Secondly does anyone use the clear back lights? If so did you replace the center white bulb with a red?? So it does not look like your going in reverse when the brake is pressed. Get A LED bulb for the interior dome. I think it's called a festoon shape. As far as I know - the only clear back lights are your reverse lights. You should have a white bulb in there so that you can see and that other people will know when you're in reverse. Quote Link to comment Share on other sites More sharing options...
VMF Posted January 31, 2006 Share Posted January 31, 2006 i do:) check out my pix in the gallery:) yes i replaced that bulb with the red LED ligt on both sides. Quote Link to comment Share on other sites More sharing options...
branshew Posted February 1, 2006 Share Posted February 1, 2006 Kewl - I just realized what you were refering to w/ the cleared tails. I would probably put a red bulb in place of a white one for the brake/tail light application if you can find one. Quote Link to comment Share on other sites More sharing options...
akewlguy Posted February 1, 2006 Author Share Posted February 1, 2006 Where does one buy the red? Or the LED (185)?? Does LED tail lights look kewl? I know autozone and westernauto do not have these items. Thanks for the information. Quote Link to comment Share on other sites More sharing options...
caoboy Posted February 18, 2006 Share Posted February 18, 2006 Kewl - I just realized what you were refering to w/ the cleared tails. I would probably put a red bulb in place of a white one for the brake/tail light application if you can find one. i know its a little old, but www.superbrightleds.com will have all the led bulbs you are looking for. Quote Link to comment Share on other sites More sharing options...
