cbroadus213 Posted January 26, 2006 Share Posted January 26, 2006 Need some advice on this one: Just took my 2000 ES300 (28K) for a routine oil change at my local Lexus dealer. Yesterday, I discovered an oil leak around the front passenger area (oil pan area?)!!! Note: I have just purchased a garage for my Lexus (home included :D) , so maybe i've never noticed this leak before when I was parking at my apartment complex. But, this is the first time that I noticed it in my garage, so I think it is new. Haven't checked it today, though. Is it normal for the oil pan, or that general area to leak a few drops after an oil change? I'm clueless when it comes to oil leaks. Maybe I should check to see what weight of oil was added? 5w30 is the correct weight, i believe. Please share your words of wisdom. Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 26, 2006 Share Posted January 26, 2006 Need some advice on this one: Just took my 2000 ES300 (28K) for a routine oil change at my local Lexus dealer. Yesterday, I discovered an oil leak around the front passenger area (oil pan area?)!!! Note: I have just purchased a garage for my Lexus (home included :D) , so maybe i've never noticed this leak before when I was parking at my apartment complex. But, this is the first time that I noticed it in my garage, so I think it is new. Haven't checked it today, though. Is it normal for the oil pan, or that general area to leak a few drops after an oil change? I'm clueless when it comes to oil leaks. Maybe I should check to see what weight of oil was added? 5w30 is the correct weight, i believe. Please share your words of wisdom. Often enough the person who changed the oil did not wipe up good enough after changing the oil filter. They almost always make a mess when they take the old one off. Keep an eye on it if it continues after a weak or so bring it back and have them look at it. You can check to see if the drain plug is tight. Probably spillage. Quote Link to comment Share on other sites More sharing options...
cbroadus213 Posted January 26, 2006 Author Share Posted January 26, 2006 Thanks dcfish! I just found a thread stating what you just said. Check it out: http://us.lexusownersclub.com/forums/index...496&hl=oil+leak Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 26, 2006 Share Posted January 26, 2006 Thanks dcfish! I just found a thread stating what you just said. Check it out: http://us.lexusownersclub.com/forums/index...496&hl=oil+leak cbroadus213, Glad you found it with the "SEARCH" feature, Your best tool on these boards. Quote Link to comment Share on other sites More sharing options...
