anitafagina Posted January 25, 2006 Share Posted January 25, 2006 My new Motorola E815 bluetooth works fine with my 2005 LS430. Now, my hubby also got a new E815 and I was able to get his bluetooth to work on the LS as well. Now, is there a simple way to switch back and forth without having to bind and rebind the phones? Or, better yet can both phone be binded at the same time. So, if either phone rings, my LS can pick it up? Thanks, Quote Link to comment Share on other sites More sharing options...
SW03ES Posted January 25, 2006 Share Posted January 25, 2006 You can't set both up at the same time, but I believe you can toggle between the two in the phone menu on the nav screen. Quote Link to comment Share on other sites More sharing options...
anitafagina Posted January 25, 2006 Author Share Posted January 25, 2006 You can't set both up at the same time, but I believe you can toggle between the two in the phone menu on the nav screen. I see. Thanks for replying. Quote Link to comment Share on other sites More sharing options...
