Serpentine Belt Replacement/ Transmission Fluid Change
mschluns
my 2000 rx 300 will be needing the serpentine belt replaced, would anybody have the maintenance instructions for this task, along with the toyota part # for the belt. i would also like to have the 4-wheel disc break procedure, calipers,rotors and pads removal and installation. along with any after markets parts that fit and hold up as well as oem. one item on transmission fluid i have ,over the last yr drained and refilled, using 4 qts toyota iv fluid a total of 4 times and my fluid is now red not brownish. shifts better also. good advice from this forum, i plan on doing this once per yr from here on out. milage on rx300 is 125,000
