rjw_mpwr Posted January 16, 2006 Posted January 16, 2006 Hi, I have a 93 ES300 with 92k miles on it. I have two problems right now. 1. The power anthena won't retract. Now, it is stuck. I can hear the anthena motor noice when I start or stop the car, like it is trying to do something. I read somewhere that I need to replace the anthena. But by looking at the athena, I cannot figure out how to get it out. Any ideas? 2. I just noticed a few days ago that except the driver side window, the power windows of the other 3 sides are not working. Nothng happens when I push the button. What is the problem? Thanks jw
Toysrme Posted January 16, 2006 Posted January 16, 2006 (edited) 1) There are multiple ways to fix the problem. Search. 2) Take the door panels off & see what's wrong with the switches. Download the factory service manual for instructions on how to do so. Edited January 16, 2006 by Toysrme
kcpth Posted January 17, 2006 Posted January 17, 2006 There can b another reason y ur windows r not going up or down. U probably shut them off. There is a button on the drivers side where u can control the windows.... there is a button to shut off the window opening capabilities. If the button is depressed... then u can't open n e of the windows. So u might want to check from there first. As for the antenna.... it's the antenna cable. The teeths might have problems. Like wut toys said... u do a search for power antenna... n it would mention the several types of fixes for it. U can also check on ebay. They have the substitute for it... just as long as the motors r running. If u want... i know i mentioned it for Toysrme *ahem* i mean Santarme.... u can download ur FSM (Factory Service Manual) for ur car. It's a pinned topic at the beginning of the ES forum. But here is the link http://us.lexusownersclub.com/forums/index...showtopic=26449 So if u need n e info on taking things out... use the FSM. But check ebay for the replacement. Remember... as long as the motor is ok... u can get the ones on ebay.
