Hi,
I have a Rx 300 with a bent power Antenna. It stills works but I want to disconnect the antenna so the motor stops trying to put it up or down. I looked in the maunal but did not see howe to disconnect. Any ideas ?
Thanks
Probably you will have to access the right rear panel in the trunk and disconnect the power lead to the motor.
  • 18 years later...
