artbuc Posted December 29, 2005 Posted December 29, 2005 My 99 RX is approaching 60k miles and I want to clean air intake with Seafoam as has been recommended on this message board. The instructions on the can give a couple of ways to add. Is there a best way to add Seafoam on the RX? If so, what is it? I was thinking of doing this: removing air supply boot from throttle body, putting the Seafoam in a spray bottle and spraying it right into the throttle body. This seems like a btter way than just pouring it into a vacuum line.
SKperformance Posted December 30, 2005 Posted December 30, 2005 The engine will not run if the maf is disconnected from the air intake
artbuc Posted December 30, 2005 Author Posted December 30, 2005 The engine will not run if the maf is disconnected from the air intake SK, where and how should I add the Seafoam? Seafoam suggests pouring it slowly into a vacuum line such as the brake booster line. I can do this but I wondered if there is a best way to do this on the RX. Maybe it really doesn't matter how I do it as long as I follow the basic instructions on the can?
wwest Posted December 30, 2005 Posted December 30, 2005 (edited) If something isn't broken why insist on fixing it...?? Unless you have been using an intake air filter not OEM or equivalent, say K&N, in which case I fully understand. Edited December 30, 2005 by wwest
