Washer Pump Replacement -95 Ls
W201 sweden
I searched the forum, but found no information regarding the washer pump. (Presume it's dead since I've found no broken fuse, and there is no sound as i press the button?)
Is it located below the battery with the fluid container?
In that case, does it mean I have to remove the front fender or bumper/spoiler to replace it?
Replies are greatly appreciated!
/Alexander from snowy Sweden
Alexander,
For the 93 LS and I assume that the 95 is similar, access to the windshield washer pump is made by removing the left front wheel well liner. So, remove the left front wheel, the wheel well fender liner, and you should be able to get at it. The same "Wiper" fuse provides power to the windshield wipers and the washer water pump so it is not a fuse problem if your wipers work. Once again, this info pertains to the 93, I hope the 95 is the same.
