I am at it again, just changed fluid on the front differential. The upper fill drain plug is a 24mm size socket which can be reached with a 6 inch extension from the rear over the cross frame. The Drain plug is a 15/16 size box end wrench WHICH is the only thing that will fit between the frame and the end of the bolt. The hardest part is getting the fluid back in. I used a little pump with about 12 inches of clear tubing to go across the cross frame into the fill hose. Again Merry Christmas to all. Next task the rear differential. couldn't do today, ran out of fluid (Synthetic 75-90 w GL5 standard Castrol oil)
