Beeping Sound
timothy
If you read the manual I think you will find that the beeping sound is generated with the vehicle skid control system kicks in. This system does use some elements of the TRAC system to apply individual brakes and reduce the power of the engine to regain traction in whichever wheel is skidding or slipping.
I think you will find the beeping is audible when the VSC light is illuminated. The VCS indicator is the picture of the car with the two parallel squiggily lines going through it.
steviej
