you don't need a grounding kit
the product is a scam , as you would be adding ultiple gorunding points which can induce noise form the charging system
it is an amazing idea to replace old wiring though
especially the main chasiss gound under the battery and the wire to the starter
i did and found the car more responsive and starter faster
but i also changed the battery and terminals
i am going to change the alternator wire next
plus i beefed up all the wiring i changed to 4 gauge with gold connectors
the kits are about 100 and for about 20 you cna buy the wire and do it your self
