No Heat On Floor.
When I turn my fan on floor, 85% of the air flow comes out the defrost vent and the 15% out the floor. When it is turn on floor and defrost it is the same result. Maybe it has always been like this. But this is the first time I have noticed it. Has anyone else experienced this problem?
Read note number 3 under the code descriptions. 21 and 24 are probably normal depending where you did the test. To look into this problem furthur will most likely require digging deep into the dash. There are other tests the Lexus dealer can do first. I would recommend giving the dealer a visit.
Edited by GuyTelefunken
