Naslund Posted December 12, 2005 Posted December 12, 2005 Guys, please help me! I’m trying to purchase a set of slighty used Enkei rims with winter tires from a guy who used them on his previous 2002 Lexus GS430. Tire size is 225/60/16 Pirelli ‘Winter 210 snowsport’ with 16” Enkei rims. Will these fit in my 1993 SC400? Do these two vehicle share the same bolt hole pattern? I was trying to find this from couple of different tire shops and one say it would fit and the other said it wouldn’t. So I don’t know who to believe. The existing owner said he bought the rims and tires from the Lexus dealer brand new and used it for only one season so they are almost brand new. It would be great if they fit to my SC400!! Please help me. Any suggestions? Thanks guys.
knmaynard Posted December 12, 2005 Posted December 12, 2005 No idea. You could make a quick call to your lexus dealership and they could tell you, I'm sure.
ZINFANDEL22 Posted December 12, 2005 Posted December 12, 2005 Guys, please help me!I’m trying to purchase a set of slighty used Enkei rims with winter tires from a guy who used them on his previous 2002 Lexus GS430. Tire size is 225/60/16 Pirelli ‘Winter 210 snowsport’ with 16” Enkei rims. Will these fit in my 1993 SC400? Do these two vehicle share the same bolt hole pattern? I was trying to find this from couple of different tire shops and one say it would fit and the other said it wouldn’t. So I don’t know who to believe. The existing owner said he bought the rims and tires from the Lexus dealer brand new and used it for only one season so they are almost brand new. It would be great if they fit to my SC400!! Please help me. Any suggestions? Thanks guys. ← Yes they should fit... Check your bolt patern all lexus bolt patern is 5x114.3 if your rims are stock 15 or 16 inch rims these 16's should be fine. Double check your vehichle info on tirerack.com just to be sure. You just punch up your info and it will tell you if they will fit. good luck
SKperformance Posted December 12, 2005 Posted December 12, 2005 They fit fine bolt patterns are both 5x114.3 with a center bore of 60.1 if it is a exact match for the bore ,otherwise get some hubcentric rings .
