justin97 Posted December 3, 2005 Posted December 3, 2005 well it was froze to the car, i didnt know that at the time. i click them on the driver side poped and now it dont move abut just a little, but the pass side works great... any insite before i tear into it?
SKperformance Posted December 3, 2005 Posted December 3, 2005 Can you move the wiper arm freely by hand?
justin97 Posted December 4, 2005 Author Posted December 4, 2005 Can you move the wiper arm freely by hand? ← yeah with very little resistances. u can hit the swithc snd it will kick up a little then go back down..
DFBonnett Posted December 5, 2005 Posted December 5, 2005 If the arm is held on by a bolt, remove the bolt and pull off the arm. If it is what I think, the arm is just stripped. You may be able to clean up the grooves in the arm and tighten down or you may have to replace the arm. BTDT.
justin97 Posted December 9, 2005 Author Posted December 9, 2005 If the arm is held on by a bolt, remove the bolt and pull off the arm. If it is what I think, the arm is just stripped. You may be able to clean up the grooves in the arm and tighten down or you may have to replace the arm. BTDT. ← well checked it out, it turned out to be the bolt on the arm was loose.. just that simple..
