PackFM Posted November 21, 2005 Posted November 21, 2005 I need to know if there is 1 hose or 2 hoses connects to the air filter box / tube? 1994 Lexus Es300
SKperformance Posted November 21, 2005 Posted November 21, 2005 Try and write something alittle longer if you want an answer!
PackFM Posted November 21, 2005 Author Posted November 21, 2005 Try and write something alittle longer if you want an answer! ← Its a simple question.
SKperformance Posted November 22, 2005 Posted November 22, 2005 To you it is a simple question. To someone who reads it with more knowledge they have no idea what "exactly" you are asking about and its location. So in order to try and fathom your question they would need to make 3 different conceivable answers for you because you felt you needed to be as brief as possible to save yourself time. Know what i am trying to say?
Toysrme Posted November 22, 2005 Posted November 22, 2005 It's a simple enough question, don't kicastrate him sk LoL! There are two hoses to the airbox. 1 is a triangular'ish one that feeds the airbox. The obvious hose is the outlet that goes to the MAF sensor & throttlebody. On a 3vz-fe the intake resonator / silencer looks like this: I've not seen a picture of a 1mz-fe one taken out in a long time, but best I remember if they're not 100% identicle, it's the exact same style. Now on the airbox to throttlebody part, there will be 1 hose going to the IAC valve under the throttlebody & one going to the front valve cover breather.
