heya , I have a Question for everyone .. Does your Tach needle go up and down , up and down When coasting down hills going about 40 mph.? You can also Feel it in the Engine ..This Car has always Done this Since I owned it...Had A Maxima that also did that..Is this Normal? just curious.If its not Normal what is the promblem .
Yes.  ;)
howstuffworks.com
Read how a torque convertor works then how an automatic transmission works.
yep, its normal, my ES250 did it. the concorde does it. the F-150 does it too. :)
I asked a tach related question about a year ago and no response. So here goes again.
Can anyone advise about the state of my tach needle? It lights up fine but either does not move at all or moves only below the 1000rpm indicator. ???
Check the wiring, wire harness, ignitor & meter circuit plate connectors
The tach itself
700rpm = 630-770ohm
1000 = 915-1115
2000 = 1920-2220
3000 = 2890-3350
4000 = 3940-4400
5000 = 5025-5425
6500 = 6650-6950
7000 = 7025-7625
The tach itself
700rpm = 630-770ohm
1000 = 915-1115
2000 = 1920-2220
3000 = 2890-3350
4000 = 3940-4400
5000 = 5025-5425
6500 = 6650-6950
7000 = 7025-7625
Alright!
Thanks Man!!
