chuckb Posted November 14, 2005 Share Posted November 14, 2005 when having my mechanic change my timing belt on my 95 ES300, should it be cheaper to have my rear valve cover gasket changed at same time? is there stuff that has to come off for belt anyway(intake,etc) that is part of valve cover job? thanks alot chuck Quote Link to comment Share on other sites More sharing options...
Toysrme Posted November 14, 2005 Share Posted November 14, 2005 No it should not. There is no reason to take the upper intake manifold off just to change the timing belt & water pump. Chuck what mileage you at? You should have a timing belt & water pump changed every 90,000m. Quote Link to comment Share on other sites More sharing options...
chuckb Posted November 14, 2005 Author Share Posted November 14, 2005 No it should not. There is no reason to take the upper intake manifold off just to change the timing belt & water pump.Chuck what mileage you at? You should have a timing belt & water pump changed every 90,000m. ← thanks. 92k miles. valve cover leak is getting on my nerves. how much is fair labor for just rear valve cover? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted November 14, 2005 Share Posted November 14, 2005 Less than an hour to do it (so round up), two if they mope around. Quote Link to comment Share on other sites More sharing options...
