Gumart1 Posted November 8, 2005 Share Posted November 8, 2005 A few members have posted here about adding a power steering inline filter to their LS's after completing a ps flush. I think it is a great idea for preventative maintenance, as long as you remember to check/replace the filter regularly. I e-mailed A1 Cardone who sells a standard inline filter as well as a premium magnetic filter asking about the differences: "You're right. I checked with the engineer & he said the (PREMIUM) magnetic one 20FLT2 was the best to use. It has a magnet, a finer filter, & a pressure relief valve in case it gets clogged. They are throwaways & like any other filter, depending on mileage, should be changed about every 2 years or 24000 mi" Dan Spang Cardone Technical Services Dept. ASE Master Certified Rockauto sells the premium filter for about $25 shipped. It is about 5" long and 2.5" wide. Should be a tight fit but offers more filtering capability than the standard which is inserted into the the return line. The standard filter is only $7 shipped. The standard is tempting with the low price, but I'm leaning towards the premium because of the built-in safety that would not allow a clog to compromise the flow. Has anyone purchased this yet? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 8, 2005 Share Posted November 8, 2005 sounds like the same ones i recommended for the RX and ES's. wix and another company makes them and can be had for under $20. They both came with the magnet and bypass. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted November 8, 2005 Share Posted November 8, 2005 thats what ive got since i rebuilt my power steering pump installed an inline filter on the return line, youve got to rreplace the old hose coz theyre short need at least a foot or so for no kinks for the filter to be inserted Quote Link to comment Share on other sites More sharing options...
Gumart1 Posted November 8, 2005 Author Share Posted November 8, 2005 It's a perfect time for me because I just finished flushing and had to cut off the old hose, so I have an ample length of new hose. Which filter did you use Bicolini? The magnetic filter requires a space of 2 and 1/2" by 5" long which is tight but I think it will work. SK is your tranny fluid still bright red with the addition of your filter? What is your typical replacement interval? Thanks for the reminder on those threads. Looks great that may be my next project. My tranny has a rough downshift when slowing under 30mph so I plan to drop the pan and clean the magnets and screen. I'll see what happens and go from there, but these filters (especially for the power steering for the LS and for the tranny in the RX) should almost be a requirement. Quote Link to comment Share on other sites More sharing options...
