seancorner Posted November 5, 2005 Share Posted November 5, 2005 Need help identifying the problem with the Seats not warming up properly. The switch does light up indicating that the heaters are on, but I get no warmth. Are there simple things I can check for? I will be checking the fuses, but I think it may be something else. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted November 5, 2005 Share Posted November 5, 2005 Need help identifying the problem with the Seats not warming up properly. The switch does light up indicating that the heaters are on, but I get no warmth. Are there simple things I can check for? I will be checking the fuses, but I think it may be something else. Thanks in advance. ← SEARCH MUCH??? Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 5, 2005 Share Posted November 5, 2005 Need help identifying the problem with the Seats not warming up properly. The switch does light up indicating that the heaters are on, but I get no warmth. Are there simple things I can check for? I will be checking the fuses, but I think it may be something else. Thanks in advance. ← seancorner, It is advisable to do a thourough search of these forums before posting a topic that could have been answered by searching, Be patient and someone with knowlege on the subject will chime in. Everyone should learn how to use these boards, Browse around and read alot, There is a test forum if you want to try something that you are not sure of. Happy posting I am sure you will find any/all the info you need here. http://us.lexusownersclub.com/forums/index.php?showforum=26 Welcome to the club Quote Link to comment Share on other sites More sharing options...
