Making Queery Sound. Help!
npcomplete
Greetings members.
Here's the problem. After the start of the engine, when I slowly step on the gas and rotate the steering wheel to the left, I hear like "grrr...." sound coming from the front right wheel. Strange thing is, after I drove the car for 1-2 mins. it doesn't seem to make that queery sound again. Will it be my time for wheel bearing replacement? Your suggestions are highly appreciated.
Thank you.
:cheers:
Are you moving or parked?
it could be from the power steering pump or just normal rust on the rotors being rubbed off by the pads.
Well, the power steering pump's more like located to the left and I've replaced all of my pads couple of weeks ago. This queery noise's been heard quite a long time and I just couldn't fint out what is causing this noise... :blushing:
