Voice Commands For Rx400h
  • 3 weeks later...
As suggested in another thread, I took pictures from the 'HELP' and then copied them into a word document and here's what you get...
From Voice Recognition Help
<Change Screen>
Map
Help
Screen off
<Change map scale>
Zoom in
Zoom out
<Change right map scale>
Right map zoom in
Right map zoom out
<Change map direction>
North up
Heading up
Map direction
<Change direction on right map>
Right map north up
Right map heading up
Right map direction
<Change guidance mode>
Dual map
Single map
Arrow guidance
Turn list guidance
Freeway guidance
Intersection guidance
Compass mode
<Register a marked point>
Mark this point
<Check route>
Entire route map
Next destination map
First destination map
Second destination map
Third destination map
Fourth destination map
<Check route>
Fifth destination map
Final destination map
<Change route>
Quick 1
Quick 2
Short
Detour
Detour entire route
<Delete destination>
Delete next destination
Delete final destination
Delete all destinations
<Guidance states>
Suspend guidance
Resume guidance
Repeat guidance
Louder
Softer
The voice commands are the non-bold words given. The bold sections delimited with <> are from the help screens. Now if we could only get Lexus to make us a card with the above we'd be in fat city! Print this out and carry :cheers:
many thanks!!!
are there no comands for other areas like air condition?
williz
for climate say the temp you want..ex..70 degrees and it will raise or lower the temp accordingly.. also if you tell it .IM Hungry. it will pull up restaruants
I found this function to be rendered usless if you don't want he AC to be in AUTO mode (Auto button on the dash - ON).
Personally, I like to be in control of where the air goes and how hard it blows, using any of the voice commands ends up causing all sorts of commotion until I can get things back under control.
