Multiple Warning Lights
larryp
Yesterday i had the following warning lights come on all at once (and they're still on):
1) Battery light
2) Brake warning light
3) Rear brake lamp failure light
4) Radiator light
5) Oil level light
I did a search and found a post with the same problem, but there was no post as to the resolution.
I know that coolant level is fine, oil level is fine, and rear brake lights work. I unplugged the battery for about 5 minutes and reconnected to reset the ECU. No change (i lost memory setting for seat and climate, but not radio - do i need to leave unplugged longer?).
Have not had battery or alternator tested, but both are about 2 years old. Car is running fine. Any ideas?
