deap9 Posted October 21, 2005 Posted October 21, 2005 When you brake it feels like the ABS brakes are coming on but no light goes on and ABS brakes should only go on in the snow and ice. It started out doing it not that often and now it's doing it more often. It also started out when you were braking and turning the wheel just every now and then. That was about 6 months ago, now it is happening very often and not only when you turn the wheel It may be the CV joints or ABS sensor? Has anyone experienced this before or know what I should do to get this fixed? Also I checked it looks good I guess I should have said all wheel drive RX 300 year 2000 with almost 90,000 Please Help Thanks Josh
SKperformance Posted October 22, 2005 Posted October 22, 2005 Does the abs light ever come on when you hit a big bump?
deap9 Posted October 22, 2005 Author Posted October 22, 2005 Does the abs light ever come on when you hit a big bump? ← So far I have not seen that happen but I don't beleve I have hit a big bump. I guess I can try that.
nosniborf Posted October 29, 2022 Posted October 29, 2022 https://carspecmn.com/lexus-rx300-abs-kicks-inantilock-brake-activation-when-not-needed/
