2001 gs 300
Has anyone ever had this issue before?
How do i fix it? could it be the sensors on the dash or something else?
I was also told to remove the fuse that controls that unit and replace it. Anyone know where to find that fuse?
That's not what guy said! Why would a fuse have anything to do with it?? <_< Unless you're just resetting it? That still won't fix the problem, maybe only temporary.
As opposed to hunting for the fuse, just disconnect the negative battery cable for 30 seconds or so. When you find that that has not done the trick, see my previous post.
After searching for the darn thing...i realized the air temp sensor is missing. What?
How much do they cost to replace?
FREE!! just go to your local lexus dealership late at night and take one off another GS!! :ph34r:
JK, i'm sure if you call up the parts dept at lexus they'll let you know.
