Transmission Flush
Where should I do a tranmission flush for my 95 SC400 with 110K miles? My independent mechanic recommended that I do it, my last transmission oil "change" was at 80K miles. I know I should flush it, so where should I do it--at the dealer or what?
A transmission flush is a fairly simple job. You can take it anywhere...don't necessarily need to go to the dealer. BUT if you are going to take it to an independent shop, I would recommend purchasing a transmission filter from the dealer prior to doing so.
