This morning on my way to work, my wife says that the brake light was intermittently going on and off.
She made sure that the emergency brake wasn't on, and it continued to happen. Then after about a mile or two down the road it stopped.
Anybody else ever experience something like this before? I haven't been able to find any threads on brake light problems.
Note: We do frequently use the emergency brake. Is this a problem?
2000 ES300 Platinum Edition
~20K miles
Hello,
1. Check brake fluid level.
Sorry, I forgot to mention that didn't I. Yeah, I checked the brake fluid level...its fine.
I'm mainly concerned if there are some known issues where using the emergency brake throws something out of wack.
I found the answer to my problem in the following threads...thanks for replying 'camlex'.
http://us.lexusownersclub.com/forums/index...topic=18311&hl=
http://us.lexusownersclub.com/forums/index...opic=19292&st=0
give that man a color TV................he used the search key.
From SKperformance and myself.........THANK YOU!!!
steviej
PS. as you will find out, even though the fluid level is above the minimum mark, Toyota and Lexus low level fluid switches are very sensitive. Add a little fluid.
