1994 Gs300 Spark Plug Gap
Is the factory spark plug gap spec for a 94 gs300 .o44? Im pretty sure it is, just double checking. Car is sitting in garage with awaiting new plugs, plug wires, cap, rotor, valve cover gasket, dist. o-ring, TPS, rear brake pads, brake system flush, and powersteering system flush. EVERYTHING is on hold until I find out the correct gapping numbers. Help ASAP would be appreciated. Thanks.
~Matt~
