rookie03 Posted September 15, 2005 Posted September 15, 2005 My 92 was just in for a checkup and they told me I need new cam seals and a distibutor o ring gasket. Has anyone had the same problem? I can understand the o ring gasket. Would all of this cause my oil leak problem? It smokes once and awhile after driving it. At first I thought it was the valve covers, but they said no.
m sorel Posted September 15, 2005 Posted September 15, 2005 I am due for a timing belt, I have been told my cam seals leak "badly" (in addition to other seals) seems pretty normal to me.
rookie03 Posted September 15, 2005 Author Posted September 15, 2005 Yeah I talked to my mechanic he said he would do the seals for 120 labor. He also said to do the timing belt if i needed it.
mburnickas Posted September 15, 2005 Posted September 15, 2005 My 92 was just in for a checkup and they told me I need new cam seals and a distibutor o ring gasket. Has anyone had the same problem? I can understand the o ring gasket. Would all of this cause my oil leak problem? It smokes once and awhile after driving it. At first I thought it was the valve covers, but they said no. ← Now clue on the distributor since I do not have one. I would do the cam seals since if they leak, they will leak onto the timing belt. If that happens, bye bye belt. These should not cause a smoking car.
Toysrme Posted September 15, 2005 Posted September 15, 2005 Depending on how bad the seals are, they can dump a boat load of oil -> even tho there isn't much oil in the heads to begin with. Normaly, any oil leak on the engine will find it's way to a y-pipe where it'll smoke up. I, originally, had a big oil leak when I had un-mounted my distributor for whatever reason after I rebuilt it. It took toooons of RTV to seal that thing, it was such a pain... Personally, if you're going to go through the trouble of paying for cam & crank & distributor seals, get valve cover gaskets too. (Most mechanics don't change the crank seal for anything.)
rookie03 Posted September 16, 2005 Author Posted September 16, 2005 The valve covers were just done, i figured the distributor oring is whats causing the smoke.
Toysrme Posted September 16, 2005 Posted September 16, 2005 It might smoke a few days if there is any oil / residue still on the engine. Let us know how it goes!
