E Dawg Posted July 14, 2003 Share Posted July 14, 2003 I have seen several cars with the overhead TV's that are usually in the SUV's. I am sure that with the moon roof things may be a little more complicated as well as the view being affected. Has anyone seen or have an overhead TV in there GS? If so by it being most likely a LCD screen is it visible by both rear passengers? I am kind of thinking of getting an overhead TV with an actuator that when I press a switch it will come down or retract. I welcome any and all suggestions. Quote Link to comment Share on other sites More sharing options...
gslx4s Posted July 14, 2003 Share Posted July 14, 2003 I have seen several cars with the overhead TV's that are usually in the SUV's. I am sure that with the moon roof things may be a little more complicated as well as the view being affected. Has anyone seen or have an overhead TV in there GS? If so by it being most likely a LCD screen is it visible by both rear passengers? I am kind of thinking of getting an overhead TV with an actuator that when I press a switch it will come down or retract. I welcome any and all suggestions. To make things easy, you should just get the headrest type of monitors. Check out the following link: http://www.vizualogic.com/ Quote Link to comment Share on other sites More sharing options...
kandygs400 Posted July 14, 2003 Share Posted July 14, 2003 haha...i have a 12inch overhead tv...my pics ar in the gallery the kandy red lexus...peep it out...im doing a 13 inch trunk screen now...have pics of that up soon Quote Link to comment Share on other sites More sharing options...
E Dawg Posted July 14, 2003 Author Share Posted July 14, 2003 Kandy is it hard for the passengers to see the screen clearly? Also was there alot of work involved in the install? Quote Link to comment Share on other sites More sharing options...
kandygs400 Posted July 14, 2003 Share Posted July 14, 2003 yes the passengers can see clearly and soo can other cars...>=X....the install will prolly take 2 hours at most a good audio shop can do it easily...i might have a screen for sale let me know if your interested Quote Link to comment Share on other sites More sharing options...
kandygs400 Posted July 14, 2003 Share Posted July 14, 2003 oh...the way i have mine mounted is after the sunroof...its actually pretty strong right there to hold the weight of the screen Quote Link to comment Share on other sites More sharing options...
E Dawg Posted July 15, 2003 Author Share Posted July 15, 2003 oh...the way i have mine mounted is after the sunroof...its actually pretty strong right there to hold the weight of the screen So does it fold up when your are not viewing it? I was thinking if I go this route that I would have some actuator hooked up so that I can have it open and close by pressing a button. Quote Link to comment Share on other sites More sharing options...
E Dawg Posted July 15, 2003 Author Share Posted July 15, 2003 I have seen several cars with the overhead TV's that are usually in the SUV's. I am sure that with the moon roof things may be a little more complicated as well as the view being affected. Has anyone seen or have an overhead TV in there GS? If so by it being most likely a LCD screen is it visible by both rear passengers? I am kind of thinking of getting an overhead TV with an actuator that when I press a switch it will come down or retract. I welcome any and all suggestions. To make things easy, you should just get the headrest type of monitors. Check out the following link: http://www.vizualogic.com/ Thanx for the link. This info is quite useful. Cheers Quote Link to comment Share on other sites More sharing options...
