New Wheels And Tires '06 Gs430
For those wondering --
20" x 8-1/2 wheels fit fine on the '06 GS430.
Also, put 245 x 35 x 20 Nitto tires on these rims, which results in about 1" taller profile on this wheel/tire combo. Fits fine.
Looks pretty sharp.
Added benefit to going to this 1" taller set-up is that it has fully corrected, the 2.5 MPH error I was seeing on my speedo (speedo has been showing 2.5 MPH faster than actual (as measured by handheld GPS). Speedo reading and reading via GPS is spot-on.
FYI.
is your 'check tire pressure' warning light on? or did you put the stock sensors in your new rims?
i heard there was a switch under the hood by the drivers side that will shut off that sensor, but i haven't had any luck in finding it.
