Ac And Stereo Works Then Doesn't, Then Works..
RottiLV
Hello,
I have a 96 LX 450 and the A.C. & Stereo turns on sometimes with start up, then there are times when it won't turn on until after the car is running, then there there are times when it won't turn on for days. Everything else works perfect, battery OK, lights OK just this intermitten pain in the butt. Please help!!!!!
Hi,
It sounds like there's some kind of shorted in wiring. If I were you, I would disconnect the stereo's power in order to isolate the problem. If you gonna trouble shoot the problem at home, you definitely need the service manuals in order to remove panel, and trace the wirings.
Thi
